AUTHENTICATION PROBLEM
Sencyty
Level 2
Level 2
Hi guys is there anyway to SSH to Catalyst 4506 switch without AAA and Radius configuration on the switch?
Richard Burts
Assuming that SSH has been correctly enabled and configured, and assuming correct IP connectivity I suggest these steps:
1) configure a local user ID with appropriate password.
2) on the vty configure login local
That should allow you to SSH to the switch.
Rick
Thank you for your response, can you please give me all the steps and
necessary commands to add?
conf t
user user1 password cisco1
line vty 0 4
login local
exit
copy run start
Rick
