Automated Shutdown of Prime Infrastructure
L.Nikulski
Hi all,
a customer has to do regular power checks in their building which includes testing UPS response times and capacity testing.  Since they are running a Prime Infrastructure Appliance in that network it could prove fatal for the database of PI if in case of a test or an actual power failure the UPS runs out of power. Instead of manually shutting down PI every time there is a test or an emergency they would like to automate a shutdown from a trigger event such as a power failure.
Is there a way to script or automate a "ncs stop" for example on PI from Traps or API calls?
Best Regards
L
marce1000
                    - There is at least no native support in Prime for that.
 M.
