Marty,
If there are no changes to the Running Configuration, then RME will not download a new configuration.
It'll still continue to check everyday based on your scheduled settings but it's not going to waste hard disk space with the same config file multiple times
So if the Startup is newer than the Running, has anyone changed the startup or uploaded another startup config manually?
The best test is to do a simple change like adding a description or adding an extra SNMP community string
or snmp location to the configuration and see if
RME pulls down the latest changes
Startup maybe more recent due to someone copying the running to the startup manually
Please verify if the Startup config is different than the running
Hope this helps
