Automatic Backup Using EEM
Cisco-Spider
Community Member
Dear All,
I want to use EEM for automatic backup of all my routers and switches on a TFTP server.
Please any 1 can help me ?
Kaven
19 Replies 19
You can add _$_event_pub_sec to get a timestamp added to the filename.
The Address pattern allows the EEM applet to respond to the interactive prompts produced by the copy command.
Perfect. Thanks Joseph.
Dear Sir,
I have enabled EEM to collect dhcp logs by copy command to receiver .but when it forwarding logs to receiver  server the file name got replaced the old file. So I want to keep all files in receiver server as per the date.
So kindly help me how could i do that. configuration file have attached.
That worked great, but I did have to add "event manager session cli username user" because the command authorization was failing since I have AAA configured.
sally.robertson
Frequent Visitor
Frequent Visitor
My EEM script is:
event manager applet BACKUP_CONFIG authorization bypass
event syslog pattern "%SYS-5-CONFIG_I"
action 0010 info type routername
action 0020 cli command "enable"
action 0030 cli command "term len 0"
action 0040 cli command "copy run bootflash:$_info_routername-config.txt"
action 0050 syslog priority informational msg "Configuration backed up!"
but it is not firing off when I save the config. What did I miss?
~Sal
