07-14-2023 01:11 AM - edited 07-14-2023 01:13 AM
Hi Expert
Recently i install 10G-LR sfp and TCL link migrated to this SFP. earlier 1G SFP was installed and ping was successful with 1600MTU but now no luck.
MTU is configured 1600byte on router interface at both end.
TCL engineer has checked every possibility and 9600bye MTU is passing in backbone. There is no issue in TCL backbone.
As i checked on my router interface there is 20843 error inputs and 20843 giants detected.
Please help with your observation and to get it resolve.
07-14-2023 01:16 AM
What configuration do you have on the router? which router is it?
07-17-2023 08:22 PM
On router:
MTU 1600
No negotiation auto
-What is the meaning of MTU 1600, is it including all required header with payload or what? When initiate ping what kind of header include with payload?
-What is the meaning of giants and when is detect on interface?
07-18-2023 12:28 PM
on IOS-XE devices - MTU-configuration might depend on device-type, interface-type, operation-system type, ...
... the interface-level command "mtu xxx" modifies the "ip mtu"-setting, which is the relevant parameter for IP-Packets.
In a Lab device "mtu 1600" changes the IP-MTU to "1600 byte", too.
You can verify, what happens at your device:
What "show ip interface" says, rules usually.
When you "ping" directly from your IOS-XE device, a "ping ...target-ip... size 1500 df-bit" generates an IP-Packet containing an ICMP-Ping-Message which has an IP-Size of 1500 bytes.
When you start your "ping" from an Windows-Command-Shell, a "ping ...target-ip... -l 1472 -f" generates a similar packet.
Service-Providers, especially if they provide L2-Connectivity might specify the L2-MTU:
..."giants" are usually frames which have been dropped in inbound direction since they exceed the local Interface-MTU.
07-14-2023 01:22 AM
Really hard to find issue here'
Change physical have no any effect to router mtu size
Change provider can lead to this'
9600 passing' how he know that if you try and 1600 drop?
07-14-2023 02:18 AM
if it's a routed backbone, it might be worth testing
to find the L2-Segment between two hops which breaks the "large MTU"-Path
