AWS Direct Connect - CSR
imleo
Hello community !
I'm trying to connect an AWS Direct Connect connection to my VPN through a CSR. I need to add the CSR because I need to set a NAT between the onpremise datacenter and the AWS cloud but I haven't find any documentation about this, can someone please give me a general guidence about this ?
The flow of the data will be:
ON PREMISE DATACENTER ---> MPLS ---> AWS Direct Connect ---> CSR(NAT) ---> VPC
The path between "ON PREMISE DATACENTER" and the "AWS Direct Connect" is already working, the only missing piece is to add the CSR
Thanks for the help !
0 Replies 0
