Backup does not start
p.calcaterra
Community Member
I have CW2000 LMS 2.5.1 on MS-Windows 2003 server and I have scheduled a daily backup, but it does not start.
In the dbbackup.log file I've found the following error message:
ERROR(992): Fatal error: Database engine 'dfmInvEng' could not be started on database 'dfmInvDb' in Bulk mode..
Backup failed: 2006/04/04 04:34:46
Where do I have to loor for?
Best regards.
Paolo C.
miheg
Level 9
Level 9
Have you configured the backup directory outside the CSCOpx directory?
Try putting it in the root of anyother drive with enough space
Michel
Thanks Michel,
the backup dir is in another drive (C:, CSCOpx is in E:) with enough space left (about 4 time the needed).
Anyway, after a deeper analisys of the dbbackup.log file, I figured out that the backup started, but due to the "ERROR(992)", the backup dir is removed from. See the shortened dbbackup.log output:
Backup to 'c:/CW2000_bck' started at: [Mon Apr 3 04:25:01 2006]
Archiving the contents of the following directories into c:/CW2000_bck\36\campus\filebackup.tar
E:/PROGRA~1/CSCOpx/campus/etc/cwsi\DeviceDiscovery.properties
E:/PROGRA~1/CSCOpx/htdocs/campus/maps
/cygdrive/e/PROGRA~1/CSCOpx/bin/tar: Removing leading `/' from member names
Archiving the contents of the following directories into c:/CW2000_bck\36\cmf\filebackup.tar
E:/PROGRA~1/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet\cwpass
E:/PROGRA~1/CSCOpx/lib/classpath\proxy.properties
Archiving the contents of the following directories into c:/CW2000_bck\36\dfm\filebackup.tar
E:/PROGRA~1/CSCOpx/objects/smarts/conf
E:/PROGRA~1/CSCOpx/setup\dfm.info
Archiving the contents of the following directories into c:/CW2000_bck\36\rmeng\filebackup.tar
E:/PROGRA~1/CSCOpx/files/rme/jobs/swim
E:/PROGRA~1/CSCOpx/files/rme/cri/archives
Starting database engine dfmInvEng
Backup failed: 2006/04/03 04:34:48
Removing directory c:\CW2000_bck\36
Note that running the immediate backup does not cause the dir to by removed. 😮
Paolo C.
