Backup ISP Failover
slam00003
Hi Guys
I am a Cisco beginner and i would like to know how can i do an ISP failover.
My set up
ASA5510
Int 0/0 WAN
Int 0/1 Inside
Int 0/2
Int 0/2.2 Voice Vlan120
Int 0/2.31 Wifi Vlan160
Int 0/3 SIP
MGMT Failover to secondary Firewall.
I would like to add our backup ISP to it, as you can see we have ran out of ports on the ASA.  is there a way we can trunk or tunnel from one of the switch ports to run a ping and if primary ISP fails the backup ISP port becomes active?
Any suggestions?
thanks
Joel
If you can patch both WAN ports into a switch that can speak VLANs (dot1q) and trunk them to int 0/0 and create  subinterfaces as you've done with int0/2 and tag correct VLAN, that will get round your lack of ports.
To failover between WAN links look at IP SLA such as below.
route primary-isp 0.0.0.0 0.0.0.0 1.1.1.1 1 track 1
route backup-isp 0.0.0.0 0.0.0.0 2.2.2.2 254 - high admin cost
track 1 rtr 10 reachability
sla monitor 10
 type echo protocol ipIcmpEcho 1.1.1.1 interface primary-isp (Example I am pinging default GW address)
 num-packets 3
 frequency 10
sla monitor schedule 10 life forever start-time now
If you're PAT'ing for outbound traffic you will need to make sure you configure for the backup ISP
Example
object network Inside1
subnet blah
 nat (inside,primary-isp) dynamic interface
object network Inside2
subnet blah
 nat (inside,backup-isp) dynamic interface
Here's an article http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
Joel
