Regular expressions in EEM - Syslog pattern
Links3000
I'd like to know how I can match a syslog pattern of BGP neighbor down, without taking into account the actual IP address of the neighbor. The normal syslog message is as follows:
%BGP-5-ADJCHANGE: neighbor 1.1.1.1 vpn vrf outside Down
What I was hoping is I can use a regular expression character to match the syslog pattern as follows "%BGP-5-ADJCHANGE: neighbor & Down", but I have not read anywhere that this is possible. Not sure if this would require a separate syslog pattern, one for "%BGP-5-ADJCHANGE: neighbor" and one for "Down", or if there is a better way to go about this? Can someone assist?
Dan Frey
This regexp will work if you want to match on any neighbor  IP.
BGP-5-ADJCHANGE: neighbor [0-9]+\.[0-9]+\.[0-9]+\.[0-9]+\s+[A-Za-z\s]+ Down
Dan Frey
Thank you!
