Bandwidth monitoring to a destination IP address
faxfan2002
Is it possible, firstly, with Ciscoworks to monitor bandwidth usage to a destination IP address. I am thinking in particular of a WAN environment (PIX -> L3 Switch -> Router)? It's worth noting that I do not have access to the router.
If not what other products will provide this very specific functionality?
Robin.
David Stanford
You can use IPM to give you some performance related statistics to see things such as round trip response, delay, and help determine any bottlenecks along a path.
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps1008/index.html
For more specific info on bandwidth utilization CiscoView has some basic graphs with real time port stats. However, there's not really anything else to give bandwidth util.
Jan Nejman
Level 3
Level 3
you can use netflow monitoring tool. You can enable
netflow export on your devices, and you need another collector/server on which netflow will be aggregated and analyzed. If you want to know more about netflow,
check web pages http://netflow.caligare.com or directly on the cisco web pages: http://www.cisco.com/go/netflow Our company distribute netflow software Caligare Flow Inspector, so if you need more information about it contact me directly.
Jan
Or go free with nTop 8)
http://www.ntop.org
