bandwidth monitoring
s4sandyad
Cisco ASR, having internet 100 mbps link, we monitor
this interface in prtg, in prtg under 60-Min & 30 Sec Interval
it shows normal utilization e.g. for out - 25 to30 mbps & for in - 20 to 25 mbps.
but when i change scanning interval time in prtg
from 30 sec to 1 sec, it shows for out - 250 mbps
& for IN - 155 mbps.
similarly in juniper devices:
when i set 1 sec interval in prtg, it shows as
35,000 kbps in
when i set 30 sec interval in prtg it shows as
6 to 7 mbps
can any body what & why this discrepancy ?? why data showing very high if I choose 1 sec interval in prtg. it showing beyond the capacity of link also. what is logic behind it.
is there load-interval related to this on cisco devices.??
how then bandwidth is monitored, how it is evaluated, can any body suggest me some documents plzz
--Sandy--
Philip D'Ath
You need to configure the "load-interval" in the physical interface to match that of PRTG.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/system_monitoring/command/reference/b-sysmon-cr-asr9k/b-sysmon-cr-asr9k_chapter_0111.html#wp1787771667
In my opinion, 1s is far too excessive.  I would not do anything less than 30s.
