Basic router configuration
tafa
Hello I am new in the networking and I am trying to configure my Cisco 888 router with 4xL2 ports. So I need to conect it to my ISPs modem and access internet. I can ping 8.8.8.8 but I am missing something to have an internet access.Thanks in advance.
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/14/16 ms
Router#show run
Building configuration...
Current configuration : 2037 bytes
! Last configuration change at 18:53:51 UTC Sun Sep 4 2022
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.2.1
ip dhcp pool Vlan 10
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip dhcp pool Vlan 20
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
license udi pid C888-K9 sn FCZ222410TN
controller SHDSL 0
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
switchport access vlan 10
no ip address
interface FastEthernet2
switchport access vlan 20
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address dhcp
ip nat outside
ip virtual-reassembly in
interface Vlan10
ip nat inside
interface Vlan20
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
2 Accepted Solutions
markanderson
You can watch this video that will help you to set up your router.
https://www.youtube.com/watch?v=FfPJ_dvM_is
make the changes marked in bold:
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
controller SHDSL 0
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address dhcp
ip nat outside
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
no ip http server
--> ip nat inside source list 1 interface Vlan1 overload
--> ip route 0.0.0.0 0.0.0.0 Vlan1 dhcp
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
end
markanderson
your LAN configuration seems like ok. also you need to configure WAN interface which connecting to your ISP device. configure ISP provided ip address for that interface and configure NAT as @markanderson shared with you.
Good luck
KB
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
controller SHDSL 0
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address dhcp
ip nat outside
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
end
tafa
Thank you all. You just saved my day. Thank you!!!
