Best Technique for Network Management
tdunlap
Is it a typical practice to install a switch (2960) at sites to intergrate CIDS, KVM switches, routers, switches, etc. This would be installed behind a 2851 and provide a path for LAN traffic and isolate management. Is there a paper that details this?
amritpatek
Level 6
Level 6
CiscoWorks LAN Management Solution (LMS) is a suite of powerful management tools that simplify the configuration, administration, monitoring, and troubleshooting of Cisco networks. It integrates these capabilities into a best-in-class solution for:
Improving the accuracy and efficiency of the network operations staff
Increasing the overall availability of the network by simplifying configuration and quickly identifying and fixing network problem Maximizing network security through integration with access control services and audit of network-level changes.
