Blocking sites using Class-Map
donceetechconcept1
Community Member
I used the Class-map command to block some websites but it did not work, this is commands i used. #class-map match-any blocksitesclass #match protocol http host *youtube* #match protocol http host *porn* #exit #do show class-map #policy-map blocksitespolicy #class blocksitesclass #drop #drop #exit #do show policy-map #int gi0/1 #service-policy input blocksitespolicy
2 Accepted Solutions
Scott_22
Level 3
Level 3
The websites you're trying to block utilize HTTPS, so the class map matching HTTP will not suffice.
Deepak Kumar
Those websites are working on the HTTPS protocol so you have to add
match protocol https
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Scott_22
Level 3
Level 3
Deepak Kumar
Deepak Kumar
Deepak Kumar,
please i need configuration of class-map on how to block sites.
thanks
