Cisco Edge WAN Router Port Forwarding
maani
Hello Everyone,  I've one old Cisco 1841 Router running as Edge WAN Router. Now, I want to forward ports through it just like any normal home routers.... Kindly help. Pasting Show run....
EdgeRouter#show run
Building configuration...
Current configuration : 1485 bytes
version 12.3
service password-encryption
hostname EdgeRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$18P8$zophbkZPasse7890xZID50
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool Local
   network 192.168.2.0 255.255.255.0
   default-router 111.111.111.14
   dns-server 84.235.6.55 84.235.57.230
no ip domain lookup
ip ips po max-events 100
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
 ip address 111.111.111.15 255.255.255.248
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 111.111.111.14
ip dns server
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
banner login ^Cine
Your Activity is being Monitored ^C
line con 0
 password 7 110A1016141D
 login
line aux 0
line vty 0 4
 privilege level 15
 password 7 0132202A7A26260635624B1D0E0A05194F58566B
 login
line vty 5 15
 privilege level 15
 login
end
EdgeRouter#
AndreaTornaghi
Dear,
you have a problem in your DHCP configuration, your default-router is 192.168.2.1 and not 111.111.111.14 .
Is your scope only NAT your network for surfing over internet or to publish an internal server?
Yes, Andrea,
we've corrected the GW in local subnet.
Router is on NAT for surfing internet service to LAN clients. Now with this we want to port forward some of internal server just like any other routers. (e.g. Port Forwarding / DMZ)
Deepak Kumar
Before starting the port forwarding let's make some correction in your configuration:
ip dhcp pool Local
   default-router 192.168.2.1
In your case, the default-router must be LAN interface IP: 192.168.2.1
Port forwarding:
Some pieces of information are missing as Port number, Internal Server IP address etc. But let's try with an example:
Suppose your internal Server IP address: 192.168.2.10 and IIS (port 443) is enabled on the server:
IP nat inside source static 192.168.2.10 111.111.111.15 tcp 443
Now if you sitting on the internet and will try to access your internal server (web page) then you need to follow steps as:
Open browser and type in the address bar as "https://111.111.111.15
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
yes You're absolutely right Mr. Kumar, the GW we configured on first configurations with Public GW then we changed it to local subnet 192.168.2.1.
Secondly,
This one line command is enough?? I mean there's no need for ACL to create??
