bulk configuration backup and command output using script (perl or batch)
mohsin.khan
Level 3
Level 3
Can you please guide me how to run a script to get configuration backup, and/or running a particular command on multiple devices in one go and then get the output in a text file?
It would be very nice, if you could give me a sample (containing the perl/batch configuration, and the step by step on how) to get output of "show version" from multiple (only IOS based) devices....
regards,
Mohsin
Michel Hegeraat
Level 7
Level 7
I think this site can get you started. It has the scripts that can do what you want
http://cosi-nms.sourceforge.net
cheers,
Michel
