BW testing
kokulsharma
We have got a new DS3 connection from an ISP. both ends are with Cisco routers (Cisco 7206). We would like to run a bandwidth test (Both upload and download)and check the maximum performance.. Is there any way we can test this? Can anyone help me in this regard......
Thanks in Advance..
Kokulan
mrmozaffari
The best thing is a "Wan Killer" it generate both tco and udp pascket and you can change the bit/second or packet/second transfer rate,i prefer to use Solarwinds Engineers Edition.
Thanks.
Please rate helpful respones.
