C1111-8P and POE
Blanca Ng
Hello everyone,
I have a Cisco router C1111-8P and Cisco AP WAP 581.
Already installed PWR-150W-AC and ISR-1100-POE4=.
but I don’t know why the WAP581 disable 5G WiFi network.
Checked the router power inline, support 30w, class 4, but just provide 15w.
may I know have any suggestions? Thanks
5 Replies 5
Thanks Leo I had try to factory rest about 2 times (soft reset and hard reset) already. And config a command: power inline auto Max 30000. Same problem. But if connect to another unmanage Poe switch (not Cisco), the 5g WiFi network should be enabled.
Console into the AP and see what it is doing.
Login to the configuration webpage no any selection about PD power
Well, seems to always get less for your cash with CISCO, this is why the poe doesn´t work:
Cisco ISR 1100 Series POE parts needed and comparison C1111-8P Why no Power Over Ethernet - YouTube
