C1111 SNMPV3 failure, not working
peter.zhu
Hi All, we encountered SNMP failure after RMA replacement, the setting remained as before, but error indicated snmp user not authorized, below is the setting and error log
snmp-server host 194.74.80.139 vrf LAN version 3 priv bt_Smarts_RO
snmp-server host 194.74.84.139 vrf LAN version 3 priv bt_Smarts_RO
snmp-server host 194.74.80.139 version 3 priv bt_Smarts_RO_BTdal
snmp-server host 194.74.80.139 vrf LAN version 3 priv bt_Smarts_RO_BTdal
snmp-server host 194.74.84.139 version 3 priv bt_Smarts_RO_BTdal
snmp-server host 194.74.84.139 vrf LAN version 3 priv bt_Smarts_RO_BTdal
snmp-server group BtRO v3 priv read bt-view write none access 19
snmp-server group BtRW v3 priv write bt-view access 20
snmp-server group Naam v3 priv read SmartsROView write none access 20
snmp-server group BT_RO v3 priv read bt-view write none access 19
snmp-server group BT_RW v3 priv write bt-view access 20
snmp-server group Makita v3 priv read customer write none
snmp-server group Smarts v3 priv read SmartsROView write none access 17
snmp-server group Concord v3 priv write Concord access 18
snmp-server group Voyence v3 priv write Voyence access 20
snmp-server group bt_Smarts_RO v3 priv
snmp-server group bt_Smarts_RO_BTdal v3 priv
Aug 11 05:43:38.574 UTC: SNMP: Packet sent via UDP to 194.102.8.14
Aug 11 05:43:38.889 UTC: SNMP: Packet received via UDP from 194.102.8.14 on Tunnel1SrParseV3SnmpMessage:Wrong User Name.
SrParseV3SnmpMessage: Failed.
SrDoSnmp: authentication failure
Aug 11 05:43:38.890 UTC: SNMP: Report, reqid 2147483647, errstat 0, erridx 0
usmStats.3.0 = 10359SrGenerateNotification: Failed to find Group name in GroupTable.
SrV2GenerateNotification:Function has reached clean up routine.
Aug 11 05:43:38.893 UTC: SNMP: Packet sent via UDP to 194.102.8.14
Aug 11 05:43:39.168 UTC: SNMP: Packet received via UDP from 194.102.8.14 on Tunnel1SrParseV3SnmpMessage:Wrong User Name.
Aug 11 05:43:39.169 UTC: SNMP: Report, reqid 2147483647, errstat 0, erridx 0
usmStats.3.0 = 10360SrGenerateNotification: Failed to find Group name in GroupTable.
Aug 11 05:43:39.172 UTC: SNMP: Packet sent via UDP to 194.102.8.14
Aug 11 05:43:39.489 UTC: SNMP: Packet received via UDP from 194.102.8.14 on Tunnel1SrParseV3SnmpMessage:Wrong User Name.
Enes Simnica
hello @peter.zhu  The log lines Wrong User Name and Failed to find Group name in GroupTable mean the SNMPv3 request is coming in with a username the device doesn’t have mapped to any group. After an RMA, this often happens because SNMPv3 users (with their auth/priv passwords) aren’t fully restored from the old box,  they aren’t shown in the running config and must be re-entered manually. And use teh show snmp user, and make sure bt_Smarts_RO and bt_Smarts_RO_BTdal exist, have the correct auth/priv settings, and are tied to the right groups. ANn if they are missing add them with the:
snmp-server user bt_Smarts_RO bt_Smarts_RO v3 auth sha <auth-pass> priv aes 128 <priv-pass>
snmp-server user bt_Smarts_RO_BTdal bt_Smarts_RO_BTdal v3 auth sha <auth-pass> priv aes 128 <priv-pass>
meaning that once the user and group match exactly, the authentication failures should stop.... hope it helps and peace!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Enes Simnica
-Enes
more Cisco?!
more Gym?!
peter.zhu
thanks Enes, I am asking security team for the password and share the result after remapping the username and group manually
peter.zhu
Hi Enes, the snmp polling back to normal after reconfig the snmp user, thanks for your kind support
@peter.zhu Happy it helped bro, and PEACE!!!!!
more Cisco?!
more Gym?!
