05-13-2019 02:00 AM
Hi ,
Just a quick question ...We have a pair of 4500X's running in VSS mode on version 3.6.6, to upgrade i konw I need to go to say 3.7.x and then to 3.8.x, however we need a rommon upgrade first.
The rommon file is "firmwareupgradeallK10-150_1r_SG15.SPA" but the documentation refers to "cat4500-e-ios-promupgrade-150-1r-SG2" .
What is the correct command to use ?
boot system flash bootflash:cat4500-e-ios-promupgrade-150-1r-SG2
or
boot system flash bootflash:firmwareupgradeallK10-150_1r_SG15.SPA
Confused I am.
05-13-2019 02:10 AM - edited 05-13-2019 02:11 AM
(Cisco's quality control ... *sigh*.)
The "latest" ROMmon for the 4500X is "firmwareupgradeallK10-150_1r_SG15.SPA".
So here's the correct method of upgrading the IOS and ROMmon of a 4500X in just ONE REBOOT:
1. Copy the IOS into the bootflash of the appliance.
2. Copy the ROMmon (filename: firmwareupgradeallK10-150_1r_SG15.SPA) into the bootflash of the appliance.
3. Change the boot variable string:
no boot system flash bootflash:OLD_IOS.bin boot system flash bootflash:firmwareupgradeallK10-150_1r_SG15.SPA boot system flash bootflash:NEW_IOS.bin boot system flash bootflash:OLD_IOS.bin
4. IMPORTANT: Make sure the config-registry is correct: 0x2102
5. Save the config
[OPTIONAL] Export the config to a remote server.
6. Reboot
NOTE: ROMmon upgrade may take up to about 25 minutes.
Hope this helps.
02-22-2021 07:58 PM
Hi Leo,
Thanks for sharing the steps which i am looking for as i am upgrading our current 4507 switch (WS-X45-SUP7L-E) Rommon and IOS from
ROMMON - 15.0(1r)SG10 -> SG15
IOS - SPA.03.04.02.SG.151-2.SG2 -> 03.11.03a.E
May i know under the steps you shared for updating the boot variable string:-
(why must the OLD IOS be added again to the boot system flash after removing it in the first step?)
no boot system flash bootflash:OLD_IOS.bin boot system flash bootflash:firmwareupgradeallK10-150_1r_SG15.SPA boot system flash bootflash:NEW_IOS.bin boot system flash bootflash:OLD_IOS.bin (why must the OLD IOS be added again to the boot system flash after removing it in the first step?)
kindly advise thank you
02-22-2021 08:26 PM
Short Answer: To prevent anyone from getting their a$$ fired.
Long Answer: IF (and only if) the NEW IOS fails to boot, the system will attempt to boot the 2nd firmware, which happens to be the old IOS.
02-22-2021 08:32 PM
Hi Leo,
i see and thanks for your speedy response! i think it is extremely important for step 4 then!
Would you have any idea if i can do a direct upgrade of IOS from 03.04.02.SG to 03.11.03a.E?
I will also upgrade my ROMMON at the same time.
I had started a post here about it - >https://community.cisco.com/t5/switching/4500x-ws-x45-sup7l-e-from-03-04-02-sg-to-03-11-03a-e-direct/m-p/4295763#M501122
