C8000 series
Ahmad A Sadiq
Visitor
Hello House,
Has anyone observed any anomalies with the cisco 8200 loosing configurations after sudden power outage or an abruptly power outage.
I have some few routers that have that issue and would love to know if it is only me facing this.
pieterh
is  by any chance the device (unintentionally) registered with Cisco DNA-Center/Catalyst-Center?
in weird cases the PnP day-zero configuration on the device is still active and DNA may be pushing a default-config to the device.
-> log the boot-process using a PC/laptop connected to the console port and force a power break
10 Replies 10
M02@rt37
Hello @Ahmad A Sadiq
what about you config register value ?
#show ver and tell us that value 0x....
Should be 0x2102
Best regards
The config register is 0x2102.
At times after the power outage. I have to change this confreg to 0x2142 after which I return back to 0x2102
Why is this necessary?
because the device doesn't allow me use the default password to login. so I have to now enter rommon mode, change the confreg value, reset, do write, change the config-register to have full access to the device
pieterh
>>> because the device doesn't allow me use the default password to login <<<
this suggests the password is not set to the default value after power outage, and also indicates the config is not cleared!
(I'm assuming you did change the default password(s)  after initial config? and/or use AAA for authentication?
NB! nowadays the user Cisco is removed during  initial configuration,
-> you need to have configured another user/password during initial configuration
Exactly! the whole config isn't cleared, however, you won't see a hostname or any other config on the device.
I actually change the default password or use AAA when the ISP is connected to the router.
pieterh
Some of the devices are which is pushing a default config.
thank you so much for this. The way out is to ensure the power outage is solved, or boot should be from packages.boot or Deregister devices.
pieterh
if you do not want this device managed using DNA Center, you can disable the PnP service
e.g. using "no pnp enable"
Thank you so much.
because most times if I want to configure the router, I need to stop pnp services in order to get the details for the CSV file.
I appreciate this.
