C8300 / C1100TG SSH Passthrough to console Port
Steffen Pontiac
Hi everyone,
we are about to install new C8300(C8300-2N2S-4T2X) and C1100TG(C1100TGX-1N24P32A) and use them as Console Terminal Server and Management Access for OOBM.
Ist it possible to configure them with a passthrough function for Console requests over SSH? I attached a sketch how I liked to connect to the console ports.
For Example:
ssh johndoe@10.10.10.99:2003
Router123#
Right now it is:
C8300#
C8300#<IP host name>
Router123#
I hope I described it clearly
BR
Steffen
Hello @Steffen Pontiac ,
There is a way to do what you described using the rotary option in IOS which controls the sty line you connect to the router:
line vty 1
 rotary 1
This config enables a new range of ports on the router - 3000+rotary number.
In our example, if you telnet/ssh on port 3001 you will land on vty 1 which is configured with rotary 1.
Now to have a certain vty connect with a specific async line, you can use the "autocommand" command on the vty line:
line vty 1
 rotary 1
 autocommand telnet 10.10.10.99 2003
Regards, LG
*** Please Rate All Helpful Responses ***
6 Replies 6
line vty 1
 rotary 1
line vty 1
 rotary 1
Regards, LG
Hi @liviu.gheorghe ,
thank you for your quick response.
Looks interesting. I will test it tomorrow or next week and come back to you if this is the solution I was lokking for.
Thank you for your great support here.
BR
Steffen
Hi @Steffen Pontiac ,
did you test it? Is it working as expected?
Regards, LG
Hi liviu.gheorghe, I am testing it today afternoon. I will report you here. Thank you for asking. BR Steffen
Steffen Pontiac
@liviu.gheorghe  I could test the function and it seems to be a good and easy solution. Thanks a lot!
BR Steffen
You are welcome. Happy to help.
Regards, LG
