C881-K9 not supported in LMS 3.2.1
mmccallebaut
We installed a new router type C881-K9. We introduced the router into CiscoWorks LMS 3.2.1 but device type was unknown and archive config was not possible (Failed). The device package installed is rtr800 7.1 and it seems that this is the latest version. As CiscoWorks is EOL is it possible that no new packages are created for our type LMS ?
AFROJ AHMAD
Hi ,
As you already know that LMS 3.2 is end of support ,so  unfortunately  there will not be any device pkg available to have this device support.
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
OK , thanks Afroz. A new reason for replacing CiscoWorks asap.
Best regards
Mike
