06-21-2025 12:41 AM
hi all
I newly brought my C9105AXI-D device connected poE cable, there is green and red light blinking on it but not showing in discoverable devises, can anyone tell me how to configure.
06-21-2025 02:00 AM
Hello @ashokch1435,
this blinking indicates that the AP is searching for its WLC but if it continues for more than 5 minutes, then the AP was unable to find or join a controller.
So you need to verify the following:
If you provide us with more details about your setup (WLC, topology, DHCP settings, etc.), then we could provice further help as needed.
HTH!
06-21-2025 04:19 AM
And just in case you don't have a controller because you bought this device as a standalone AP, you can convert it to EWC-mode (embedded wireless controller):
The EWC has already been announced as EOL, but it could be a viable solution for the upcoming time.
