C9500-24Y4C Stackwise Virtual non compatible with Prime Infrastructure 3.7
When we are using the switch as standalone they come up in prime.
When we activate Stackwise Virtual it comes up as unsupported device in prime.
We are using Cisco IOS XE Software, Version 16.12.01c on the switches.
When I look through the release notes of different software versions I can not see that prime 3.7 is supported for this device.
https://www.cisco.com/c/en/us/support/switches/catalyst-c9500h-24y4c-switch/model.html#ReleaseNotes
My question is when will there be a software for C9500-24Y4C that supports prime version 3.7
Mark Elsen
 - It's usually the reverse; will there be a version of Prime that supports you configuration. You can also verify the current setup against :
               https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Have you installed the latest "Device Pack" yet?
rune.jon
I remember those days when the Cisco engineers stood on stage and said there will not be a release of a new Cisco platform that was not also supported in Prime when released. Not even the documentation is updated:
6 months and nothing has happened. We are at 3.8...
Is 9500 in stackwise virtual setup that uncommon?
What is the roadmap for support?
DNAC suported this setup in 1.3.1.3
So since there is a no documentation of support matrix the procedure is to install/upgrade to 3.7 and THEN check.
Supported Devices
To see the list of devices supported in this release of Prime Infrastructure:
Procedure
Step 1
Log in to Prime Infrastructure.
Step 2
Click the wheel icon at the top right, then click Supported Devices.
If you post output of this you will help others.
Martin2m2
First I have to agree that a C9500-24Y4C in VSL is absolutely NOT uncommon. I have more than one customer with that setup. And also that updates to the documentation is a bit lacking for Prime Infrastructure.
Now for the good news, it seems to be supported now in 3.8. Can someone confirm this?
See: https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/prime/infrastructure/3-8/supported/devices/PI38-Supported-Device-List.xlsx
Note - SVL supported for C9500-24Q,C9500-12Q,C9500-40X,C9500-16X,C9500-32C,C9500-32QC,C9500-48Y4C,C9500-24Y4C
- I say what I mean and I do what I say -
