C9500-48Y4C Unsupported Cisco Device on Prime Infrastructure 3.5
Hello
We have a problem Cisco Prime Infrastructure 3.5, when we discover C9500-48Y4C with feature stack wise in Cisco Prime, device type detection "Unsupported Cisco Device". Any solution for this problem?
Mark Elsen
 - Check compatibility information for your device from the link below :
                            https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello Marce1000
We have checked the compatibility device, but the issue is whether this might be the effect of the stackwise feature?
The 'culprit' it's the stackwise configuration.
The official reply I recieved from the TAC some time ago is that they don't know if\when the Prime team will add support for 9500s in stackwise configuration.
Leo Laohoo
Raise a TAC Case and see if they can knock up a device pack for 3.5 or wait for the release of PI 3.7 (and pray it will be supported).
