Cable: Cisco Catalyst 3750 to Blackbox termserv
ethanmonat
I'm hoping someone out there will have the pinouts to connect the console port on a Catalyst 3750 to a Blackbox Rack Terminal Server 16 port.
The Blackbox is using RS232 V.24 on UTP8 with RJ45 connectors:
1 - DCD
2 - RTS
3 - DSR
4 - TxD
5 - RxD
6 - GnD
7 - CTS
8 - DTR
If I had a breakout box and logic analyzer I'd just find it out myself, but my workplace isn't that well equipped. Since Cisco's console cable is non-standard and the Blackbox's V.24 is hardly used, I'm having a really hard time finding documentation on fabricating a cable. Since the BB has DCD and DSR inputs, I'm worried about having to spoof signals. Can anyone help?
thomas.chen
Level 6
Level 6
Try doing the following on the Black box.
1. Click on the Cables & Connectors option from the Products column
2. Choose the Cisco option.
3. Choose the Smart Serial Cables for Cisco Routers option
4. the choose the DB-15 female cable.
Hope this helps
I wish this did help, but it doesn't. Since I was trying to connect a PIX 525 firewall which uses a RJ45 connector for console to a Blackbox termserv which also uses a RJ45 connector for it's connections.
However, I was also in contact with BB's tech support, which turned out to be suprisingly fast and helpful. For anyone interested, the following pinouts are what is required:
The Pinout is
"TERMSERVER" "CISCO"
3----BLACK------2
4----RED--------6
5----GREEN------3
* 6----YELLOW-----4 * 2 CONDUCTORS IN # 6
* 6----BROWN------5
7
8----GRAY-------7
I custom-made a cable, and all is well.
