Call Manager 5.0
bsudol79p
Hi, I have been trying to backup the Call Manager with SFTP, I have tried several different SFTP server but none of them seem to work. The logs show that the Call manager is connecting but then it is disconnected. Does anyone have a good SFTP that backuped up the Call Manager? I tried Titan, FreeSFTPd and other products. Your help is appriciated. Thanks
robv
check out SecureFX (and/or VShell if you need it)
www.vandyke.com
can't say enough good things about their stuff.
robv
www.vandyke.com
Rob,
Did you have any luck using Vshell on a 2003 server for the backups. I am getting some issues and would love to know what steps you took to mnake it all work.
At this point i am just getting disconnected when i try to do the backup.
here is what is in the logfile on the vhsell server.
15:21:20,auth,00055: Client specified username domainname\username, resolved as domainname\username
15:21:20,auth,00055: none for user domainname\username rejected because it is unavailable
15:21:20,auth,00055: Received unsigned public key; checking authorization (fingerprint: 6c:0c:d7:55:de:bf:e1:73:cc:9f:f4:ac:38:47:c8:33)
15:21:20,auth,00055: Searching C:\Program Files\VShell\PublicKey\username for matching public key
15:21:20,auth,00055: No matching authorized public key found
15:21:20,auth,00055: publickey for user domainname\username rejected
15:21:21,auth,00055: password for user domainname\username accepted
15:21:21,conn,00055: Session channel open request accepted
15:21:21,conn,00055: Received request to start subsystem sftp (Built-in Subsystem)
15:21:21,sftp,00055: SFTP subsystem initialized; remote version is 3
15:21:21,sftp,00055: Sending VERSION packet to remote (3)
15:21:21,sftp,00055: Failed to stat file: /dUmmI_Drf as user: username System Error: The system cannot find the file specified.
15:21:21,sftp,00055: Failed to open /dUmmI_Drf: Access is denied.
15:21:21,sftp,00055: SFTP subsystem terminated
15:21:21,conn,00055: Session channel has been closed (pid: none)
15:21:21,conn,00055: Connection closed
any ideas?
looks like an authentication issue. suggest not to do the push right from CM, first test your vshell config is setup OK using a plain SFTP client (SecureFX). debug at forums.vandyke.com -- their support folk hang out there. once vshell is working then test the CM backup using the same credentials. if still fails? get packet capture on the vhsell server using wireshark & examine for odd things.
good luck,
R.
Rob,
Thanks for the quick reply. I figured it out. I was just putting a "/" for the directory and need to put "/ailasname"
