Campus Manager
Network Dude
I wonder if anyone can help, I have 7 Cisco 3750s that as soon as the Data Collection Schedule kicks in, every 4 hours, SNMP stops on the switches.  The switches are still available on the network however Fault Manager and our separate SNMP monitoring tool flag up the issue.
I have other 3750 switches with the same IOS on them and they are not affected.
Has anyone seen this before?
Thanks in advance,
David.
5 Replies 5
Joe Clarke
When this problem occurs, you need to capture the output of "show stack PID" from a switch where PID is the process ID of the SNMP ENGINE and IP SNMP processes.  You may need to run these commands a few times in quick succession while the problem is occurring.  Post the output as well as the show version from the switch.
Hi there,
Thanks for that d sorry for the late reply, I have been on holiday.  Here is the output from sh stack PID
#sh stack 253
Process 253: IP SNMP
Stack segment 0x407A8B0 - 0x407D790
FP: 0x407D6C0, RA: 0x1254EE4
FP: 0x407D780, RA: 0xA6B34
FP: 0x407D788, RA: 0x941AF0
FP: 0x0, RA: 0x9387B8
#sh stack 253
#sh stack 253
#sh stack 255
Process 255: SNMP ENGINE
Stack segment 0x40806C8 - 0x40835A8
FP: 0x40831E8, RA: 0x1254EE4
FP: 0x4083220, RA: 0x51FC70
FP: 0x4083238, RA: 0x58AFB4
FP: 0x4083260, RA: 0x58B1B8
FP: 0x4083340, RA: 0x587E7C
FP: 0x4083360, RA: 0x5893F4
FP: 0x4083380, RA: 0x58978C
FP: 0x4083388, RA: 0x41D904
FP: 0x40833A0, RA: 0x94642C
FP: 0x40833B0, RA: 0x946584
FP: 0x40833C8, RA: 0x9468F8
FP: 0x40833D0, RA: 0x41D364
FP: 0x40833F0, RA: 0x117D5C0
FP: 0x4083428, RA: 0x117BDBC
FP: 0x4083470, RA: 0x115EAB0
FP: 0x40834D8, RA: 0x1135D78
FP: 0x4083540, RA: 0x1128B1C
FP: 0x4083598, RA: 0x114FFCC
FP: 0x40835A0, RA: 0x941AF0
#sh stack 255
I have also attached the switch config.
I really appreciate your hep with this.
David.
I need the show ver from this switch to be able to decode the stack.
Morning Joseph,
Attached is the sh ver as requested.
Thanks again for your help.
David
This looks like CSCsz89393.  If switch stacks contain more than four high-capacity switches, SNMP can be slow to respond.  The fix is in 12.2(50)SE3 or 12.2(52)SE.
