CampusManager Map Design Problem
ozlemduran
We are using CM3.3 and after I created and designed a map, one of my friend trying to open my map.
Map contents ok but design is different, map is coming with default view.
is there a solution for that???
thanks
vergeerf
In ~CSCOpx\campus\etc\users per use a directory is created with preferences and layout files (one xml file per view) you can copy these file to other users
~CSCOpx\campus\etc\cwsi\users has a preference file for usertracking
vergeerf
vergeerf
In ~CSCOpx\campus\etc\users per user a directory is created with preferences and layout files (one xml file per view) you can copy these file to other users
