Can not access ASDM and to use TFTP in cisco asa 5505
Hamid Amir
Dear All
I have problem to access ASDM and to copy using tftp in ciscon asa 5505, I can ping to the Ip address
192.168.1.1.
I get error message  for ASDM
192.168.1.1 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
For TFTP
WARNING: TFTP download incomplete!
%Error reading tftp://192.168.1.1/E:\ASABACKUP\asa992-smp-k8.bin (Unspecified Error)
Can you help please?
Kind Regards
Hamid
It is not clear to me which way the tftp is trying to do. Some look like the ASA is the source while others look like the ASA is the destination. And in each of the commands supplied there appears to be an E drive. Perhaps there might be an E drive on the remote machine. But I have never seen an E drive on an ASA. Perhaps it would be helpful to clarify what is the destination machine and what is the source machine, and what and where is the source file and what and where is the destination file.
Rick
10 Replies 10
 Are you sure about this path:
" tftp://192.168.1.1/E:\ASABACKUP\asa992-smp-k8.bin "
Seems to me that some bars should be in the other way around.
Hamid Amir
Yes that what with command, I did use third party tftp software (PumpKIN), I get message aborted.
ciscoasa# copy tftp flash:/disk0:
Address or name of remote host [192.168.1.1]?
Source filename [E:\ASABACKUP\asa992-smp-k8.bin]?
Destination filename [/disk0:/E:\ASABACKUP\asa992-smp-k8.bin]?
Accessing tftp://192.168.1.1/E:\ASABACKUP\asa992-smp-k8.bin...
Kind Regards
Hamid
check the TFTP size in ASA.
Sorry I do not know how to check the TFTP size in ASA, however I can not even copy small txt file.
Kind Regards
Thanks for the Link, I h
ciscoasa# copy tftp disk0:
Source filename [E:\ASABACKUP\asdm-7161-150.bin]?
Destination filename [E:\ASABACKUP\asdm-7161-150.bin]?
Accessing tftp://192.168.1.1/E:\ASABACKUP\asdm-7161-150.bin...
%Error reading tftp://192.168.1.1/E:\ASABACKUP\asdm-7161-150.bin (Unspecified Error)
ave already tried it.
Can you ping tftp from management interface ?
Rick
Hi Richard
Thank you very much for your help, you saved my life again.
Yes, It was mistake.
Kind Regards
Hamid
Hamid
You are welcome. Glad to see you continue to be active in the community.
Rick
