can not delete $ sign
Hello All
İ have a command in router , there is a dollar sign $ before my ip address and i can not delete it.
ip dhcp database scp://username:password@x.x.x.x/$172.24.1.110.txt write-delay 900 timeout 450
it gives that error ;
% scp://username:password@x.x.x.x/72.24.1.110.txt is not in the database.
5 Replies 5
manually type:
and when you come to the $ sign, type Ctrl+V, then enter the $ sign...
I also have the same problem. I tried your suggestion. but it didn't work.
it gives that error:
$172.2x.x.x.txt write-delay 900 timeout 450
thx for reply my friend but not working
save the running configuration to a TFTP server, exit the text file, then copy it back to the running config...
