10-11-2013 07:46 PM
HI,
I have installed my LMS 4.2 on the EXSi 5.0 recently,but i can't log in the web ,i login into the console,and "show application status LMS ",it display as follows:
LMS02/sysadmin# show application status LMS
INFO:Daemon Manager is not fully initialized. Process State will be updated.
Process State Pid
ESS Program started - No mgt msgs received 1256
EssMonitor Running normally 1306
EventFramework Program started - No mgt msgs received 1323
SyslogCollector Running normally 1324
RMEDbEngine Program started - No mgt msgs received 1325
ANIDbEngine Program started - No mgt msgs received 1433
MACUHIC Running normally 1470
UTLITE Running normally 1471
IpmDbEngine Program started - No mgt msgs received 1472
UPMDbEngine Program started - No mgt msgs received 1582
UPMDbMonitor Running normally 1619
DFMLogServer Program started - No mgt msgs received 1622
DFMCTMStartup Program started - No mgt msgs received 1623
FHPurgeTask Not started yet 0
DfmBroker Running normally 1624
DfmServer Running normally 1783
DfmServer1 Running normally 1784
FHDbEngine Program started - No mgt msgs received 1785
INVDbEngine Program started - No mgt msgs received 2086
PMServer Running normally 2123
EPMDbEngine Program started - No mgt msgs received 2144
EPMServer Program started - No mgt msgs received 2211
AdapterServer Program started - No mgt msgs received 2302
AdapterServer1 Program started - No mgt msgs received 2303
FHServer Running normally 2304
DFMMultiProcLogger Program started - No mgt msgs received 2305
CSDiscovery Not started yet 0
DCRDevicePoll Not started yet 0
CSRegistryServer Running normally 2306
Tomcat Program started - No mgt msgs received 2307
TomcatMonitor Program started - No mgt msgs received 2442
Apache Not started yet 0
TopoServer Not started yet 0
LicenseServer Not started yet 0
FDRewinder Not started yet 0
NameServer Not started yet 0
NameServiceMonitor Not started yet 0
EDS Not started yet 0
CmfDbEngine Not started yet 0
CmfDbMonitor Not started yet 0
DCRServer Not started yet 0
CMFOGSServer Not started yet 0
TISServer Not started yet 0
DFMOGSServer Not started yet 0
NOSServer Not started yet 0
PTMServer Not started yet 0
InventoryCollector Not started yet 0
Interactor Not started yet 0
InventoryCollector1 Not started yet 0
Interactor1 Not started yet 0
UPMProcess Not started yet 0
IPMOGSServer Not started yet 0
ANIServer Not started yet 0
UTMajorAcquisition Not started yet 0
WlseUHIC Not started yet 0
UTManager Not started yet 0
VNMServer Not started yet 0
EssentialsDM Not started yet 0
ICServer Not started yet 0
EnergyWise Not started yet 0
ConfigMgmtServer Not started yet 0
PMCOGSServer Not started yet 0
ConfigUtilityService Not started yet 0
CAAMServer Not started yet 0
EDS-GCF Not started yet 0
jrm Not started yet 0
DataPurge Not started yet 0
IPMProcess Not started yet 0
CTMJrmServer Not started yet 0
ChangeAudit Not started yet 0
SyslogAnalyzer Not started yet 0
diskWatcher Not started yet 0
LMS02/sysadmin#
LMS02/sysadmin#
for this scenriao,what's the reason?
could you help me ?
my web browser is IE9.0. and JavaScript is enable.
10-11-2013 08:00 PM
Your LMS application is not all the way up in the output above. Most importantly (as far as the user interface goes), Apache is not started yet. That is the web server used by LMS.
If it remains that way after 30 minutes, I would restart the VM and see if it comes up. If it still doesn't, then I'd say your installation may be corrupted. If it's brand-new, I'd try a reinstall.
10-11-2013 08:22 PM
it indeed remain that after a few days , and i reinstall a new system , i reload the VM(LMS) ,it looks like the same ,then i will try to restart my VM machine and see its status.
thank you .
10-15-2013 06:32 AM
Got the same problem since this morning. LMS Version 4.2. Seems like Apache wont start. Got no clue where to search. Been looking at log files all morning.
Process State Pid
ESS Program started - No mgt msgs received 12610
EssMonitor Running normally 12650
EventFramework Program started - No mgt msgs received 12676
SyslogCollector Running normally 12677
RMEDbEngine Program started - No mgt msgs received 12678
DfmBroker Running normally 12797
DfmServer Running normally 12912
DfmServer1 Running normally 12913
FHDbEngine Program started - No mgt msgs received 12914
EPMDbEngine Program started - No mgt msgs received 13236
EPMServer Program started - No mgt msgs received 13317
AdapterServer Program started - No mgt msgs received 13392
AdapterServer1 Program started - No mgt msgs received 13393
FHServer Running normally 13394
INVDbEngine Program started - No mgt msgs received 13395
PMServer Running normally 13759
IpmDbEngine Program started - No mgt msgs received 13924
UPMDbEngine Program started - No mgt msgs received 14061
UPMDbMonitor Running normally 14118
ANIDbEngine Program started - No mgt msgs received 14119
MACUHIC Running normally 14176
UTLITE Running normally 14177
CmfDbEngine Program started - No mgt msgs received 14178
CmfDbMonitor Running normally 14311
DFMLogServer Program started - No mgt msgs received 14331
DFMCTMStartup Administrator has shut down this server 0
FHPurgeTask Never started 0
DFMMultiProcLogger Program started - No mgt msgs received 14333
CSDiscovery Never started 0
DCRDevicePoll Never started 0
CSRegistryServer Running normally 14334
Tomcat Program started - No mgt msgs received 14335
TomcatMonitor Running normally 14471
Apache Administrator has shut down this server 0
DCRServer Never started 0
CMFOGSServer Never started 0
TISServer Never started 0
DFMOGSServer Never started 0
NOSServer Never started 0
PTMServer Never started 0
InventoryCollector Never started 0
Interactor Never started 0
InventoryCollector1 Never started 0
Interactor1 Never started 0
UPMProcess Never started 0
UTManager Never started 0
EssentialsDM Never started 0
ICServer Never started 0
EnergyWise Never started 0
PMCOGSServer Never started 0
ConfigMgmtServer Never started 0
ConfigUtilityService Never started 0
CAAMServer Never started 0
VNMServer Never started 0
WlseUHIC Never started 0
IPMOGSServer Never started 0
TopoServer Program started - No mgt msgs received 14593
LicenseServer Program started - No mgt msgs received 14594
FDRewinder Never started 0
NameServer Program started - No mgt msgs received 14595
NameServiceMonitor Program started - No mgt msgs received 14688
EDS Running normally 14712
ANIServer Never started 0
UTMajorAcquisition Never started 0
EDS-GCF Running normally 14780
jrm Never started 0
DataPurge Never started 0
IPMProcess Never started 0
CTMJrmServer Never started 0
SyslogAnalyzer Never started 0
ChangeAudit Never started 0
1019 Never started 0
1157 Never started 0
diskWatcher Running normally 14781
10-15-2013 08:18 AM
I also did a ./web_server -t to check the apache server and it comes back with the following error:
error while loading shared libraries: libaprutil-1.so.0: cannot open shared object file: No such file or directory
