can not see anything in 24 hour syslog message summary for cisco 7201 router
rana.samir
We have Cisco Works LMS 3.0.1. Our router Cisco 7201 can not see any numbers on 24 hour syslog message summary.
I can see data for that router in our syslog.log file.
Any help would be appricated.
Samir
Your syslog filters are wrong.  You have enabled all of them, but set the mode to keep.  Set the mode to Drop, and you should start seeing messages.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Joe Clarke
Post screenshots of RME > Tools > Syslog > Syslog Collector Status and Syslog Filters.  What are some of the messages you see from this device in syslog.log?
Hi ,
Please find the attached screen shot of message filter, syslog collector status and some of the
messages from syslog.log for this device.
Samir
You are osum man.
It solved my problem.
Thank you very much.
Samir
