can somebody help me ? vlan 10,20,30 perfectly getting IP´s from
Roman Mihal
vlan 10,20,30 perfectly getting IP´s from server but other vlan´s ain´t can somebody please check it and try to fix it ? everything is correctly configured I guess :}
Hallo,
I have added the HSRP configuration to all remaining Vlans, find attached the revised file (saved in PT version 8.1).
8 Replies 8
 Can´t open your file but let me ask you a feel things.  About those others vlans:  Did you created then in the switch or switches ?
If there are trunks, did you allow then on trunks?  What is the exit of the command :
show spann vlan XXXX ?
the problem is that you don't have HSRP configured for Vlans 40, 50, and 60. The default gateway for .e.g. Vlan 60 on the DHCP server is set to 192.168.1.65, that IP address does not exist anywhere. Is that design on purpose, half of the Vlans with HSRP, the other half not ?
where did you find the 192.168.1.65 ip? HSRP is not configured because i found this problem and i was trying to fix it so maybe it is a problem i ll try to configure it on other vlans . thank you
do you need HSRP configured on Vlan 40, 50, and 60 as well ?
yes i do , can i send you a IP chart and can u try to do it please ? because im done . i dont have enough nerves for it
Hallo,
I just have any words . I appreciate it so much . thank you
no problem. This stuff can get confusing sometimes...
