Can't access https on nexus
Charlers Duong
Community Member
Hello Everyone,
I have configured mgmt 0 and enabled nxapi on switch but I can't access https via mgmt. My troubleshooting is: I successfully pinned from PC to IP Mgmt switch the but from sw: ping PC's IP vrf management to the PC (PC turns off firewall), which I failed. Can you assist me ?
Thanks a lot
Mark Elsen
 - Configure the device according to :
     feature nxapi                          ( Enables NX-API)
     nxapi {http|https} port port    ( Specifies a port)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
