Can't access WS-SVC-NAM-2 module through http or telnet
mohamed louhab
Hi ,
i try to access to WS-SVC-NAM-2 module in the Switch 6509. But is not work although the http port is enabled (I tested with the command
telnet  @ip 80).
I try telnet access to the module to check the config , but I always the message that the login / password is wrong even though they are valid.
Any suggestions?
thanks.
AFROJ AHMAD
Hi ,
Please enable this commad on the NAM and see how it work:
ip http server enable
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Ahmed ,
thank yoou for your help ,
but when I try telnet access to the module to check the config , I always the message that the login / password is wrong even though they are valid. (So I can not verify this command )
when i do "telnet @IP_module 80"  in my PC , i can access to module via telnet ( it can prove that the port 80 is open)
thanks ,
HI Try this :
WS-SVC-NAM-2 Password Recovery Procedure: The default CLI password for the NAM is root/root (all lower case). To recover the NAM CLI Password: CatOS: "clear module password " from the switch enable mode IOS: "clear module pc-module password" from the switch enable mode To recover the Web GUI Password: For NAM's Web GUI admin password, you can reset it again from the NAM CLI using the NAM CLI command "rmwebusers". Here's an example: ---- root@6K# rmwebusers WARNING: Doing this will stop the web server and remove all locally defined web users from web user database. Are you sure you want to continue (y/n) [n]? y Disabling HTTP server... Successfully disabled HTTP server. All locally defined web users have been removed from web user database. root@6K# ip http server enable Enabling HTTP server... No web users are configured. Please enter a web administrator user name [admin]: admin New password: Confirm password: User admin added. Successfully enabled HTTP server. root@6K# ---- Reference Documentation: You can also refer to the NAM User Guide which have this listed: http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/3.
4/user/guide/appxa.html
I hope this will help
Afroj
mohamed louhab
Salam  Ahmed ,
i will try that , and I will reply soon
Thanks Ahmed )))
