Can't add Nexus 5010 to LMS 3.2
adery6300
I'm trying to add two Nexus 5010 switches to a vanilla LMS 3.2 (RME 4.3, no device update), and I'm getting nowhere : I add the switch, enter the credentials, I click Finish, everything is normal up to here.
But the switch is not present in device manager, nothing about it in RME Jobs/ Inventory...
What log can I check to see what's wrong ? Couldn't find anything in dcr.log or rme.log...
Thank you!
Alex.
Nael Mohammad
Level 5
Level 5
Did you configure the nexus to use SNMP ?
Here is an exmaple:
snmp-server host 1.1.1.1 version 2c public
snmp-server host 1.1.1.1 use-vrf management
Also it would be a good idea to run the device package update to get the latest RME device support. Go to Common Services ---> Software Center --> Software Update --> Select all the applications ---> and Download Software Updates and then Common Services --> Software Center ---> Device Update --> Select all products --> Check for updates.
Rebooting the LMS server fixed the initial problem. Now I'm having an inventory problem with the Nexus, but I'll open a new thread for it.
Thanks!
Alex.
