Can't Connect Message CNA
ischarcm
running newest version. For some reason no matter what switch in our network (or ap) I try to connect to it says it cant connect. I can HTTP to the switches. Running this on XP. I've tried all levels, read only, etc. Any ideas?
smahbub
Level 6
Level 6
I think it might be a problem or the bug in the latest version, check by downgrade the software . I hope it will work.
