Can't create VLAN's with Cisco Network Assistant
Holzwurmch
Hello everyone
I have a problem with my newest Switch, a WS-C2960X-48TS-L
Normaly I can programm all my Switches with Cisco Network Assistant. But now I have a problem with creating VLAN's. I can create them, safe them but after a refresh, all the new VLAN's are gone!
I updated the CNA to the newest Build 6.0 and updated the Switch to 15.2(2)E, but nothing helps!
Over the CLI I can do everything, but this is not a option for me! To programm sometimes a switch CNA is perfect for me! If it works!!
Tobi
adamtodd16
Level 3
Level 3
So if you do it via CLI, you have no issue at all? Or have you tried this to verify?
Do you have STP enabled on the switch?
yes I can programm the vlan's over CLI. That's works. I have not tested this if its really works, but the VLAN's are programmed.
hmm I checked the STP / VTP settings with a second identical Switch, but there are no differents. Made a backup of one Switch and restore on the other One, but I'm still not able to create VLAN's.
however, I contacted my vendor today, he tell me that it shouldt be a problem to take back the switch.
Best regards
Tobi
