Can't Start Deamon LMS3.2
microtel
Hello All;
I have pb with deamon lms3.2
when i try to start the service with net start the following message appear:
CiscoWorks Deamon Manager could not be started
the service did not report an error.
Ciscoworks run on windows server 2008 Standard SP1 and the the virtual memory to double the size of your physical RAM
Thank you for your help
AFROJ AHMAD
Hi ,
Is the Server in Domain ?
Run the below command  :
NMSROOT\CSCOpx\setup\support>resetCasuser.exe
--Now try to start the Daemon Manager..
--if this does not work , attached the syslog.log and screen shot of the Error (if any)..
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
Thank you for your prompt answser.
The problem was in the antivirus installed on the Server.
I uninstalled it and the service Deamon manager functioned
The following document should help you with future process down situations:
https://supportforums.cisco.com/docs/DOC-14520
The need to have an exclusion setup for the anti-virus on-access scanning is also mentioned here.
