Can You tell me, my monitoring sensor will be interested for anybody or not?
Oleg Volkov
Hello.
I make many sensors for PRTG.
I want to see EIGRP neighbours status and make single sensor with multiple channels (for PRTG free edition )
Sensor get all EIGRP neighbours in all AS and save it to JSON file.
After this, You can stop sensor, edit JSON and add names.
Then You need delete and add sensor again, because PRTG do not allow delete old channels.
Also I make BGP sensor but I will make documentation in near future.
You can download and use it for free.
https://github.com/OlegPowerC/psPowerEIGRP
Also I send it to PRTG Script world but today
Helping seriously ill children, all together. All information about this, is posted on my blog
6 Replies 6
Oleg Volkov
Description:
Fixed  error with neighbor loss.
Now it work correct
Fixed UPTIME error
Also new BGP sensor:
https://github.com/OlegPowerC/psPowerBGP
Oleg Volkov
Now at scrip world:
https://www.paessler.com/sensor-hub/all/all/all?origins%5B0%5D=10&origins%5B1%5D=6&origins%5B2%5D=9&origins%5B3%5D=3&stats=all&fulltext=oleg&newOnly=false&scroll=859&key=1620156222751
When I try to use your script I am getting this error:
This version of %1 is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher. (0xD8)
