Capture running config automatically
jimmymbara
Community Member
Does anyone know a utility or script to capture running config on switch/router automatically or periodic and save the configuration on PC??Thanks
viswanathan123
Level 3
Level 3
Hai,
Here is a tool called CiscoConf available on COSI.
http://cosi-nms.sourceforge.net/alpha-progs.html
Hope this information is useful to you.
If so please rate it.
mfreeman451
Level 3
Level 3
Or if you want something that is supported, and you have the money, check out TrueControl NAS from OpsWare (http://www.opsware.com)
