Castlerock SNMPc not recognizing ASR1002-HX interfaces
Larry Sullivan
Level 3
Level 3
Hopefully a simple solution here.  I am trying to monitor the line status of a couple of interfaces on an ASR-1002HX (asr1000-universalk9.16.06.02.SPA.bin)  Problem is, Castlerock (Version 9.0.2) can not seem to pull interface information from the device.  When you try to display interface index/stats nothing comes up.  It works with other model routers automatically.  Below are the only SNMP configs on it.  My understanding is the server-host "IP" command is only for sending notifications to, so isn't needed to pull interface stats, although I did try adding that as well with no luck.  I'm having a go of it trying to figure out why CR won't pull interface info on this device.  Do I have to download and add some sort of additional MIB?  Any help is appreciated.
snmp-server community "XXXXX" RO
snmp-server community "XXXXXXXXXX" RW
Larry Sullivan
Level 3
Level 3
Larry Sullivan
Level 3
Level 3
No experience in this field huh?  Alrighty.  Plan B.
Larry Sullivan
Level 3
Level 3
No resolution.
