Problem with privileges - 12.2 IOS
Filip Knezevic
We have a problem with user privileges on some older devices, mainly Cisco 6509.
The problem is I don't know how to assign all possible sub commands of a command, namely ip route.
So, for example, colleagues from L1 department can do static routes, but they cant name them. Now for me that is a big issues since they are just piling the routes with no description, which is making troubleshooting harder and it looks really ugly.
On newer IOS (15) you can do:
privilege configure all level 2 ip route.
This will allow all the iterations of the ip route command.
But on IOS 12.2 there is no all subcommand.
R2D2-NEW(config)#privilege configure ?
level Set privilege level of command
reset Reset privilege level of command
R2D2-NEW(config)#privilege configure lev ?
<0-15> Privilege level
R2D2-NEW(config)#privilege configure lev 2 ?
LINE Initial keywords of the command to modify
The result is this:
 R2D2-NEW(config)#ip route 8.8.8.8 255.255.255.255 1.1.1.1 ?
<1-255> Distance metric for this route
<cr>
Cisco says (if I understood correctly) that first couple of keywords for a command will enable all sub commands but it's not working.
R2D2-NEW(config)#privilege configure level 2 ip route name. - This is not working.
Any advice?
Upgrade to new IOS is out of question since we can't risk any issues with these devices. There are a lot of links there and if it wouldn't come back up after an IOS upgrade lot of stuff could potentially go wrong and that would be a catastrophe.
Leo Laohoo
Duplicate thread.
Please post all response(s) into the main thread (HERE).
