Cat3750 temperature
pppyyyppp
We are running 3750 ((C3750-IPBASE-M), Version 12.2(25)SEB4).
show env temperature
TEMPERATURE is OK
Is there an OID that we can get to snmp monitor the switch temperature?
7 Replies 7
rajinikanth
Level 3
Level 3
Check this link with MIBS for temperature check.
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=OLD-CISCO-CHASSIS-MIB
Hope it helps u
Raj
andrew.burns
Level 7
Level 7
Temperature values are only supported on the following switches:
3750G-48TS, 3750G-48PS, 3750G-24TS, and 3750G-24PS
Andrew.
Hi Andrew,
Our switch is WS-C3750G-24TS-S. When do show env temp, it shows only "TEMPERATURE is OK".
Do you have the OID for the temperature values?
show env temperature status
Temperature Value: Not Supported
Temperature State: Not Supported
It's look like the temperature value is not supported.
Andrew, can confirmed this.
A quick note on the output of the Catalyst 3750. show env power only shows the status of the built-in power supply. If you are using an RPS on this system, you need to use show env all to get the RPS status as well
kingdwight1
This is not the OID you are looking for but if you run show env temperature status
you should get something like this...
MY-SWITCH1# show env temperature status
System Temperature Value: 31 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
Hope that helps future readers.
