Catalyst 4500 series switch does not generates log message for intf...
rezaalikhani
Hi all;
I have a Catalyst 4503-E with the recommended Cisco IOS on it (cat4500es8-universalk9.SPA.03.11.03a.E.152-7.E3a.bin). My problem is that, although I executed the terminal monitor command on it, it does not generate log message for this event:
Any ideas?
Leo Laohoo
For the Catalyst 4k, interface-level "logging event link-status" is disabled by default.
With this in default, whenever a link goes down or up, it does not send any log entries.
balaji.bandi
does the logs show when you issue show logging ?
BB
Thanks for your reply;
Unfortunately no!
Leo Laohoo
