12-26-2015 09:46 PM
Hi Guys,
I've got a console connection to Catalyst 6500 with 2 supervisors via terminal server, what would be the right way to determine to which of supervisors console I connected to?
Swich software:
s3223_rp Software (s3223_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
Supervisor model:
Policy Feature Card 3 WS-F6K-PFC3B with MSFC 2A daughterboard WS-F6K-MSFC2A
12-27-2015 06:22 AM
Hi ,
use the below command to the active n standby Sup::
**show module
**show redundancy
Thanks-
Afroz
**Ratings Encourages Contributors ***
12-27-2015 06:33 AM
These commands does provides information regarding supervisor status, but what I would like to know, if it is possible to know to which supervisor console port you are connected at the moment.
Show line does not state it
#show line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 0 4 1/2439 -
