Catalyst 9000er series - Webinterface Access RADIUS won't work
malawi
Hi guys,
my problem in a few lines:
- I can't access the webinterface of my 9300-48T, 9300-24T, 9500-40X via RADIUS authentication
- But I can access via radius over ssh
- I can access the webinterface with local credentials
- I configured "ip http authentication aaa"
- On my 2960X-models it work's without any issues
There is the following log-message on one of my 9000-Switches:
Apr 18 09:42:45.056 cest: %WEBSERVER-5-LOGIN_FAILED: Switch 2 R0/0: nginx: Login Un-Successful from host 172.20.0.19 using crypto cipher 'ECDHE-RSA-AES256-GCM-SHA384'
Login-failure:
Can anybody tell me a solution oder put me in the right direction?
Many thanks!
18 Replies 18
Mark Elsen
 - Check the radius server's authentication logs when this is tried ; if there's no activity then the auth-setup is (still) incorrect.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you marce1000,
on the RADIUS server there is no activity when I try to access over the webinterface. But there is activity when I try it over ssh.
I'm confused about this because the authentication over ssh works perfectly and over https it doesn't work.
Therfore I would exclude the "auth-setup is incorrect" thing.
 - If the radius servers sees no incoming authorization request, when the web interface is tried  , then it means that there is something wrong with the intended and or needed configuration on the switch (I am afraid).
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Yes, it sounds plausible. But I don't understand, why our firewall logs a package when I try to login over the webinterface !?
This means that the switch sends a packet to our radius-server. But at the server is no packet incomming. No error, no logs, nothing.
But on the 2960X I have the same configuration and it works. Maybe there is a bug in the webinterface on the 9000er series...
Over ssh it works on the 9000er series, too! Only with webinterface there is a problem.
SW-Version: 16.10.1
 - Not at all!  There will always be activity in your firewall logs when you access the web-interface of the Catalyst for whatever reason (network traffic) . You  are deviating from the real problem which I already explained.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Well, there is a packet logged with port UDP 1645 in the firewall. As fare a I know thats a "Radius-Port".
I did exactly the same configuration steps on both switch types (2960, 9000series):
aaa new-model
aaa authentication login default local group radius
aaa authorization exec default local group radius if-authenticated
aaa accounting system default start-stop group radius
radius server radius1
   address ipv4 1.2.3.4 auth-port 1812 acct-port 1813
   key 0 radiussharedkey
radius server radius2
That's all...
Did you ever find a resolution for this?
Perhaps the following commands will help you:
ip http authentication aaa login-authentication radius
ip http authentication aaa exec-authorization radius
Jasper Lampitoc
Hi All,
I have the same problem and scenario, is deleting crypto pki trustpoint TP-self-signed can resolve the issue or not?
You certainly can try deleting the trustpoint for self signed but I would be surprised if that solved your issue. The original post included having a log message about crypto cipher, do you have any similar log message? It might be helpful if you would post your config or at least all of the config related to aaa, to http/https, and to radius.
Rick
Hi Sir Richard,
Good day.
Kindly see below configuration:
aaa new-model
aaa group server radius xxxxxTest
server name xxxxx
aaa authentication login RadiusTest group xxxxxTest local
radius server xxxxx
address ipv4 x.x.x.x auth-port 1812 acct-port 1812
key 7 yyyyyyyyyyyyyy
ip http server
ip http authentication aaa login-authentication RadiusTest
ip http secure-server
Logs was like this
*Mar 17 13:22:28.249 PHT: %WEBSERVER-5-LOGIN_FAILED: Switch 1 R0/0: nginx: Login Un-Successful from host x.x.x.x
*Mar 17 13:22:35.288 PHT: %WEBSERVER-5-LOGIN_FAILED: Switch 1 R0/0: nginx: Login Un-Successful from host x.x.x.x
but on SSH i can successfully login using the UN PW from radius server
Hope you can help me,
Thanks for the additional information. When you attempt to access the web interface would you then check the logs on the radius server and see if there are any messages related to your attempt?
Rick
This was the logs from radius server
Jasper
Thanks for posting the log message from the Radius server. It is quite surprising. Radius says successful and the switch says failed. So we need to look deeper. Can you make sure that the logging level for logging buffered is set to 7, attempt to login, and check logs? Perhaps the next step would be to run debug for radius and for aaa authentication and see if the debug output gives us anything helpful.
Rick
