ISA-3000 ftd-boot issue
mark.stewart1
Hi, a colleague was upgrading some ISA-3000 devices to the ftd firmware, but has some how come unstuck with this one and now it has come to me to look at, below is what i get when trying to tftp the ftd-boot file.
ADDRESS: 192.168.100.131
NETMASK: 255.255.255.0
GATEWAY: 192.168.100.1
SERVER: 192.168.100.130
IMAGE: ftdboot.lfbff
MACADDR: 4c:5d:3c:b4:90:21
VERBOSITY: Progress
RETRY: 40
PKTTIMEOUT: 7200
BLKSIZE: 1460
CHECKSUM: Yes
PORT: GbE/0
PHYMODE: Auto Detect
Receiving ftdboot.lfbff from 192.168.100.130!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
Boot buffer bigbuf=348bd018
Boot image size = 160342672 (0x98ea290) bytes
[image size] 160342672
[MD5 signaure] 0e12e78f26e43fadbf1a5a08d823de5f
Signature verification failed for key# 1
Failed to validate digital signature
LFBFF signature verification failed!!
Signature not verified. No kernel found to launch.
tried simple filename, re-erasing disk0:, disabling local firewall on pc(unlikely due to getting valid tftp session)
anybody an ideas???
thanks,
mark.
5 Replies 5
marce1000
 - Start by verifying md5sum of software downloaded target file and compare with cisco as specified on cisco download site.
 M.
ok, interestingly, the MD5, on my pc matches the one from the cisco website.
but the md5 shown on the device after it has downloaded is totally different???
tried two different tftp servers now also.
tried solarwinds and tftpf64
any ideas?
thanks,
mark
                   >...but the md5 shown on the device after it has downloaded is totally different
 - Should not be different can you check the involved tftp server(s) logs and  check if the transfer can be completed successfully ?
 M.
I assume 'IMAGE: ftdboot.lfbff' is not the original file name ? What is the full original file name (e.g. ftd-boot-9.16.2.5.lfbff) ?
Sorry original filename in attempt below, that was purely and simply to try a very simple filename just in case.
rommon 13 > tftpdnld
IMAGE: ftd-boot-9.15.1.0.lfbff
VERBOSITY: Progress
RETRY: 40
PKTTIMEOUT: 7200
BLKSIZE: 1460
CHECKSUM: Yes
PORT: GbE/0
ICMP port unreachable: from 192.168.100.130.
Receiving ftd-boot-9.15.1.0.lfbff from 192.168.100.130!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[MD5 signaure] 268fc78ed18a7e31b524c765c0211c9d
